AODE/4R70W Analog Issues *Fixed*
64bit
Post by 64bit »
There isn't a whole lot of information about running the AODE/4R70W with Microsquirt while using an analog sensor. While I managed to get my system operational, it is fairly limited.
BLUF: The analog gear position settings for the 4R70W should only have 3 voltages instead of 4 (or a resistance value... see below), and OD should be controlled via switched input (Selector D?)
So let me get back to the details here. Ford uses a low voltage signal and reads resistance of the MLPS circuit, much like a traditional thermistor. The compatibility with Micro requires either replacing your harness and running the digital MLPS... OR, opening up the analog MLPS and soldering a jumper to the beginning of the circuit, adding a wire to the harness, and using TPSv to supply 5v and take the shifter position out as a SIGRTN. I opted for the latter.
The issue with this is the sensor only has 6 internal voltage posistions (P,R,N,D,2,1) while TS is looking for P,R,N,4,3,2,1. This is obviously an issue that could probably be cleaned up relatively easily with a small code change to the firmware. I have dug into it slightly, but cant quite find the correct places to make the necessary changes.
As of right now, I can set manual shift mode and use 1,2,3 forward gears... but OD is inop (no 4th voltage). If I set Auto mode, I have to set 3rd gear voltage to 0.00, and 4th to the voltage seen in D position. Then allow the Micro to control when to shift into OD. This method seems to be working fine... BUT. I cant shut off OD like I could with the factory PCM (button push).
I have more questions... but lets start here.
No MSQ attached, because it isn't needed.
1994 Mustang Cobra
351w Turbo w/MS3 GoldBox xTra
4R70W Analog w/ Microsquirt TCU
64bit
Re: AODE/4R70W Analog Issues (requires code correction)
Post by 64bit »
Anyone want to field this one?
Before I pull the Micro out and just run a Baumann.
Sent from my SAMSUNG-SM-G930A using Tapatalk
1994 Mustang Cobra
Raymond_B
Post by Raymond_B »
I feel your pain, I tried to use a Microsquirt for my E4OD, but it's just too experimental for me. I imagine most of James's time is used up with Megasquirt development.
FYI, the Quick4 is pretty awesome :)
http://www.buildpics.org/
I'll try to have a look later this week.
64bit
Post by 64bit »
jsmcortina wrote:I'll try to have a look later this week.
I greatly appreciate it. If you need any further info from me, ill be watching the thread.
1994 Mustang Cobra
That was a long week, looking today.
64bit wrote:As of right now, I can set manual shift mode and use 1,2,3 forward gears... but OD is inop (no 4th voltage). If I set Auto mode, I have to set 3rd gear voltage to 0.00, and 4th to the voltage seen in D position. Then allow the Micro to control when to shift into OD. This method seems to be working fine... BUT. I cant shut off OD like I could with the factory PCM (button push).
What do you think would be the best way for this to work?
I would expect the 'D' position to be set for 4th gear voltage.
What is or isn't happening with the OD button?
Oh yes it is and a datalog showing any problems you have.
64bit
Post by 64bit »
So, like I said... There are 6 positions on the shift position sensor.
P, R, N, D, 2, 1.
There is no 4th gear voltage available.
So, my suggestion is to make OD a push button disable, just like stock. So the logic would be that OD can only be used when the switch is on, and the car is in D.
If you honestly think my MSQ will help. I'll send it to you, but I've posted all the info.
1994 Mustang Cobra
I'm pretty sure that when I implemented this I was told that the button was OD CANCEL. I think I originally made it OD enable, but was told that was wrong.
I have never seen a vehicle with this trans. My cars are manuals.
Raymond_B
Post by Raymond_B »
My 1995 Lightning is definitely push-button *disable*
64bit
Post by 64bit »
Yes, on a factory car, You push the button to disable the use of OD. But you're also talking about a completely different PCM and tuning system.
James, what do you need from me... That will help you easier understand what I need for this to work?
1994 Mustang Cobra
64bit wrote:James, what do you need from me... That will help you easier understand what I need for this to work?
Tune and log. I won't look at it without them.
What exactly isn't working with the "OD disable" button input? I need a clear explanation that matches what is shown in the datalog.
64bit
Post by 64bit »
A log isn't going to help you, because the issue is directly in the firmware settings of the trans control software.
As you see in this picture, I have 4R70W Analog selected.
There is no option to control OD with a switch... And there should be.
In this image you will see that I have to set voltages for 1st, 2nd, 4th, N, Reverse, and park.
Your programming calls for 7 voltages, and the sensor cannot physically produce them.
You need to fix this to be P, R, N, 3, 2, 1.
Here is an internal shot of the sensor, so you'll have a better understanding.
After modification, each one of the pads shown, correlate to a gear position. Again... 6 positions, not 7.
There is no shifter location for 4th(OD).
So the 4R70W analog setting needs to have an OD cancel (or enable) feature by button.
I do not want to post my MSQ. I can put my project on my Google drive and PM you the link. But I will not post it here.
1994 Mustang Cobra
64bit wrote:So the 4R70W analog setting needs to have an OD cancel (or enable) feature by button.
It does.
64bit
Post by 64bit »
Not according to what Tunerstudio is showing.
1994 Mustang Cobra
Without MSQ and MSL, I'm not able to help you. Sorry.
64bit
Post by 64bit »
jsmcortina wrote:Without MSQ and MSL, I'm not able to help you. Sorry.
youve got a link in your PM. although they arent going to help.
1994 Mustang Cobra
64bit
Post by 64bit »
I could be reading these incorrectly... but im pretty sure
#define TRANS_SELECTOR_D (trans == TRANS_E4ODA) || (trans == TRANS_E4ODS) || (trans == TRANS_W4A33)
should include
trans == TRANS_4R70WA
I found these in trans_init.c
the 4l80E has four manual drive positions on the shifter. same as the 4L60E. The 4R70W, both analog and digital, as well as the AODE found in the 94-95 Mustang (for example) only have three manually selectable drive positions.
1994 Mustang Cobra
Yes it looks like TRANS_4R70WA needs to be included in that one line.
I think that a big part of the problem here is documentation. The manual doesn't mention that the OD button switch needs to connect to selector input D.
I could really do with more input from customers that have working installs to validate the manual. As far as I know only 4L80E and 4L60E have off the shelf wiring available, so the rest of these applications are presently DIY.
64bit
Post by 64bit »
Well, I looked into your 1.0.2beta2 firmware and upon the initial code inspection, it seems to show the 4R70WA as having the OD switch functions. I am running the 1.0.1 firmware on the main msextra page.
I will get 1.0.2beta2 flashed in and report my findings.
The car runs and drives, and I can provide the documentation necessary to release an updated version of the trans manual. But the OD functionality is critical... Especially to me.
1994 Mustang Cobra
