Hi, I’m kinda new to this and I was wondering how you would make a circuit like this on the picture.
Do you use a prototype print board ? Or just make a big clump of wires with tape around it ?
Proto type printboards, how to?
- Attachments
- B7622ED2-2557-46EE-AEB6-C18D827ED457.png (108.04 KiB) Viewed 692 times
Kent
Supra mk3 2jz-gte
Ms3pro ultimate (installing)
Microsquirt trans control (installing)
Denmark
Supra mk3 2jz-gte
Denmark
Re: Proto type printboards, how to?
Easiest way to make a one off is stripboard - called Veroboard in the UK.
If it is just for testing the circuit use a breadboard.
If you make a proto use a pcb and solder it together.
There are lots of types PCB to choose from, search for perfboard of proto pcb.
It’s not just for testing I’m hoping it’s actually gonna work and be installed in the car
I might be able to borrow a breadboard before final install.
Maybe one of you two can help me out here
I’m gonna be using the schematic I posted, but I don’t need L and the car is alway gonna drive with OD on because I don’t have an OD switch. I only have P R N and D. Can I just remove the wires from OD and L ?
Kent
Supra mk3 2jz-gte
Denmark
Supra mk3 2jz-gte
Denmark
James maybe you can tell me how to rewire it when I’m not using OD and L
Kent
Supra mk3 2jz-gte
Denmark
Supra mk3 2jz-gte
Denmark
