Solenoid A and B stats not logged ?
hi guys,
i made a log file now that my trans shifts like I wannt. I cant seem to find the signal/channel for FIDLE and FUELPUMP that are used for SOLENOID A and B of my 4L80E.
are they logged under a different name?
i have attached the log file for you guys to check it out.
https://drive.google.com/open?id=1zh9i3 ... 09w327EDb_
my project page, BBC 454 with LPG vapour injection:
my BBC 454 LPG vapour injection tuning story
my Facebook projectpage:
My 1977 GMC C15 Suburban "Storm"
Re: Solenoid A and B stats not logged ?
LAV1000 wrote:Check this one
http://www.msextra.com/forums/viewtopic ... 38&t=68039
;-) thats my topic. and what I noticed in shadow Dash is that the solenoid stats are not what I expect every now and then. So Id like to check a datalog on it.
but they dont seem to be in the data log. from what I can judge
Made a printscreen of your Datalog 2018-01-12-14.11.
And there is a SolStat.
- Attachments
- Solstat !.png (46.62 KiB) Viewed 734 times
ok, thank you.
I was looking for the FIDLE and FUELPUMP output signals, because thats what the Solenoid A and B are connected to physically.
Solstat in the manual says:
Guess I dont know how to read this Solstat and know which solenoids are acitvated
but is does not say "what or how it represents" those solenoids?SolStat
A bitfield representing the solenoid outputs.
Eh, second posting jn the forementioned topic ??kikkegek wrote:LAV1000 wrote:Check this one
thanks, but thats not quite correct then. I checked my logs and thiss is what I found.
Solstats from Shadow Dash:
and this is whats avaiilable in the log file:
during driving I see SOL A and B sometimes turn off and on, while there are no gear changes....thats why I wanted to check the logs to see if that a glitch in the MS Shadow Dash app i need t report of if the trans is actually switching solenoid A and B on/off for some reason.
so far I can judge right noww, there is no way in the available data that is logged, to see wich solenoid is activated. I wonder wwhy? because they are stock outputs you'd expect to see in the log files. so maybe something simple that can be fixed for future fiirmware?
Code: Select all
Sol1 = Shift solenoid A
Sol2 = Shift solenoid B
Sol3 = Line pressure solenoid
Sol4 = Lockup on/off
