pm reply not working.
I was recently pm'ed and when I replied the message is in the out box, along with another pm I tried to send. my out box has 2 pm's in it and I can't figure out how to send them. I thought they would be sent when I hit the send button after creating the answer.
Re: pm reply not working.
The pm will remain in your outbox until they are read by the recipient. What you are seeing is perfectly normal.kaeman wrote:I was recently pm'ed and when I replied the message is in the out box, along with another pm I tried to send. my out box has 2 pm's in it and I can't figure out how to send them. I thought they would be sent when I hit the send button after creating the answer.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
thanks Ken. I was just confused because a regular email goes to the sent items as soon as you hit the send button it doesn't remain in the outbox.......
