hello,
I want to add a picture to a private message, how can I do? There aren't the "Add an attachment " menu but I see a button with "Img*" on it: I don't understand how to use this button, could someone explain to me?
Ludovic
sent a picture with a private message?
V3 with MS II (blue board),Code v2.35,MT 2.25 + ford EDIS:
Engine: 1300 cc hyundai (G4EH), 4 cylinders, port injection.
- MS/Extra Guru
When you mouse over the image button, the box directly above the message text box (the one you're typing in) should say:
So that says start with the img tag {img} then put the URL to the image in plain text, then close the img tag with {/img}. (I've substituted the open and close brackets with squiggle brackets so it doesn't turn it into code)
So for instance:
Will make the HTML in the page to actualy load the image like so:
Hope it helps!
-Brian
Code: Select all
Insert image: [img]http://image_url[/img] (alt+p)
So for instance:
Code: Select all
[img]http://www.geocities.com/briandavid78/store/images/100percent.gif[/img]
Hope it helps!
-Brian
