Get RUnning w/Microsquirt V3 with MSextra
ZZR1200 Kawasaki engine with stock Kawasaki VR sensor and 24-2 trigger wheel.
The wheel and pickup gave a good signal on the homemade bench, but I'm not getting 5v from the µs.
Beyond the ECU I am using a wasted COP config with a Bosch 211 igniter that's heat-sinked and wired per the manual. Coils are some Kawasaki that measure 1.6Ω. I thought I would wire the coil's wasted pairs in series where they have 3.1 Ω resistance. I know folks shouldn't wire coils in series, but I know of hundreds that do this with the stock igniter since it requires 3Ω coils and it works quite well in those instances.
I have Waverruner throttle bodies and TPS sensor, the GM CLT, IAT, and 3 Bar MAP from DIYAutotune and four 440cc high Z injectors.
Innovate LC1 and Bosch sensor.
It is a turbo setup.
If I could find a spark I think I'd be golden, but I'm missing something somewhere. I think my hardware is all OK. Now that it's on the bike, just cranking and measuring voltage off the pickup I get +/- 0.9V
Logging gets me a half second of RPM (around 200) and then that's gone. Please help me. I've read for days until I am about to have a brain bleed. LOL
Re: Get RUnning w/Microsquirt V3 with MSextra
Here's a picture of the VR 24-2 M-N setup.
OK, no one new has even looked at this the last day. It's most likely in an inappropriate location anyway.
But since no one has responded at all, I think my only option is to abandon the Extra code for now and try to get something going with the standard code even though it's not what I want in the end. I need this thing running ASAP.
Thanks for looking anyway.
Blessings,
chuck
Blessings,
chuck
This is in the location for questions about the forum itself.
By not getting 5 volts, do you mean that there is no voltage at VREF? If not, where did you measure?
MATT!
I was just about to send you an email. Thanks for responding.
I measured on the ignition out looking for the 0,5v logic signal.
That is only a valid test if your multimeter has a peak mode or if you used an oscilloscope. Can it fire the spark in output test mode?
I'm thinking not since I get no injector output either, but I'll give it a shot as soon as I get home in a bit.
Thanks again Matt.
Thanks again Matt.
Reversing the VR polarity fixed it up. Thanks again for the help.
chuck
chuck
