Traction control using factory 2 wire abs sensors
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
Ms36262cobaltLS
Post by Ms36262cobaltLS »
Ok I have a 06 cobalt with a ms3x ecu I'm trying to look into traction control I have factory 2 wire abs sensors I was thinking using the rear wheels for a VSS signal and using the front hubs for wheel slip but as far as I know it's AC and the ecu can only read DC I need some ideas and information to what I can do I have herd maybe trying to run a HAll sensor for wheel speed but not entirely certain how I would mock up a wheel hub trigger wheel for the sensor I'm trying to build a good drag setup car so traction control, rolling anti lag and eventually I need to figure a way to do boost by gear and build something to tell ecu what gear car is in
old guy
Re: Traction control using factory 2 wire abs sensors
Post by old guy »
Google LM2917 which is a frequency to voltage converter chip. This will take your AC signal and convert it to a DC voltage proportional to your wheel speed.
Download the application notes as they have some good circuit examples.
Post by Matt Cramer »
For MS3, just get some VR conditioners like the dual VR board sold by JBPerf.com.
