Build logs?
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
tbaggins
Build logs?
Post by tbaggins »
Is there an appropriate forum to post build logs? I have a 2003 4.6 2v mustang that I will be converting to megasquirt over the next few months. I currently have a quarterhorse tuning package, and I am going to be using (if possible) values from the stock ECU tune as a base. I think it would give other people with the EEC-V V8's that are making the switch a good place to start.
2003 Mustang 2V stock harness splice, MS3X v3.0 parallel install, full sequential, HPX MAF, Ford Ev6 47lb injectors, COP, custom 8 BIP373 box, E85 pump, teflon lined return style fuel system, 39 lb base fuel pressure, Twin Turbo @ 7lbs boost, Dual 4 port boost solenoids, Dual 14point7 widebands
