Tach signal from ms3x
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
Postby Ms36262cobaltLS » Thu Aug 04, 2016 4:42 pm
I have a cobalt with aftermarket VDO tach looking for ways to wire in the tach signal my question is what's best way to wire it in? I have a ign-4 coil tower running my ignition could I just use one of the negative side wires on the tower plug? Or would tach output on megasquirt work with my VDO gauge ? Any input helps thanks
Ms36262cobaltLS
Re: Tach signal from ms3x
Postby slow_hemi6 » Thu Aug 04, 2016 5:08 pm
You can trigger from one of the negative sides of the IGN4 but you have to set your tach up for 2cyl. Needle might have a little jitter at idle but is steady when revs climb. But the tach out from the megasquirt should work fine also.
Cheers Luke
slow_hemi6
Return to How Do I...
