I have a new MS3 installation on a 88 Jeep Wrangler with straight 6 converted to MPI.
I don't think I'm getting a good/consistent signal from my crank trigger. What's the best way to test for that? What voltage should I see when I'm testing?
Thank you in advance for help!
Regards
Crank Trigger
Re: Crank Trigger
You will probably get more responses if you post in the MS3 section of this forum.
Also, give a little more information, such as.
What kind of trigger wheel?
What kind of sensor?
What kind of coil?
Remember, the more information you can give, the easier it is for someone to troubleshoot your problem.
What kind of coil?
Re: Crank Trigger
Thank you... I've re-posted in the MS3 section with additional info.
