12v Circuit Design Software
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
DonMaximo
Post by DonMaximo »
I can sit here with pencils, eraser and create a schematic for my 12V circuits that would include battery, switches, relays, resistors, wiring, sensors, ECU, etc. Sure would be nice to indicate wire gauge as well. I could then share this diagram with others to get a 2nd pair of eyes on what I intend to do.
Is there a relatively inexpensive or free software solution to doing this ?
My thought is that the software provides a simpler means for correction and alterations later on, not to mention my memory is not what it once was. Should would be nice to keep it with the car.
Thoughts - Suggestions ???
TIA,
-D
1992 Mustang Conv,
363" Man-o-War (8.2"Deck), Dart Pro-1,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
Innovate DLG-1 (dual WB O2)
Ignition LS2 coil on plug (Crank trigger+ Explorer cam sensor)
DonMaximo
Re: 12v Circuit Design Software
Post by DonMaximo »
Found an interesting product --- kicking tires with free demo now
www.circuitlab.com
1992 Mustang Conv,
NA, EFI Victor,
TKO600, 373 gears,
MS3-Pro
DaveEFI
Post by DaveEFI »
I use what's called generically CAD software. One free one for a PC is DraftSight. They use a common file format which is cross platform. Includes a library, so you can use symbols others have created or make your own. Being vector based, it can be enlarged to any size with no loss of quality. It can also be used to create all sorts of technical drawings, which can drive a CAD cutting machine directly. Here's a couple of examples:-
Ted75zcar
Post by Ted75zcar »
Check out Eagle from Cadsoft. They have a free version as well as a scalable upgrade path. Eagle is a full featured capture/layout and DRM package that approaches the functionality of the high end packages.
Use the largest frame available in the free version to get the most single sheet workspace.
