My dumb question is, can I fit a WBO2 in the collector on one bank only on my V8, the bridge between the two banks is so far towards the back.
If I could fit a sensor in both collectors, but would there be an advantage over one?
Should I???
Should I???
Re: Should I???
It's pretty common, if your budget won't fit two widebands.
Re: Should I???
Thanks Matt just what I needed to know. I'm working on a Stag V8 (not Rover V8). The packaging under the bonnet is really bad on the offside and there is no room on that side. Ideally I would fit a WBO2 both sides if I could, but as long as just one side is OK, then that's fine.Matt Cramer wrote:It's pretty common, if your budget won't fit two widebands.
