Should I???
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
Carboy0
Should I???
Post by Carboy0 »
My dumb question is, can I fit a WBO2 in the collector on one bank only on my V8, the bridge between the two banks is so far towards the back.
If I could fit a sensor in both collectors, but would there be an advantage over one?
Re: Should I???
Post by Matt Cramer »
It's pretty common, if your budget won't fit two widebands.
Carboy0
Re: Should I???
Post by Carboy0 »
Matt Cramer wrote:It's pretty common, if your budget won't fit two widebands.
Thanks Matt just what I needed to know. I'm working on a Stag V8 (not Rover V8). The packaging under the bonnet is really bad on the offside and there is no room on that side. Ideally I would fit a WBO2 both sides if I could, but as long as just one side is OK, then that's fine.
