fuel level sensor on 2000 camaro to ms3 without ecu
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
BoostedBitch
Post by BoostedBitch »
looking to read my factory fuel level sensor on ms3pro without having the factory ecu on the car. Any help would be grateful.
Re: fuel level sensor on 2000 camaro to ms3 without ecu
Post by Matt Cramer »
What's its resistance at full and empty?
BoostedBitch
Full is 260 and empty is 40
OK, I'd try something around a 150 ohm pull up resistor to 5 volts. Then use a linear calibration with zero = 1.05 volts and 100% full = 3.17 volts.
