How do i upgrade my map sensor?
Do you need some help in using the forums? Any questions about using the forums can be asked here.
Contact a: System Administrator
Postby superboost » Thu Apr 27, 2017 4:18 pm
Hi guys! I have a mslabs ms2pnp for my (96-97 turbo miata) and it has only a 2.4bar map sensor in it. I want to upgrade it to a 3.5 or 4bar map sensor as i am going to be aiming for more boost in my car. So is upgrading the map sensor as simple as opening my ms2, desolder the old map sensor, solder new map sensor and then choose it from tunerstudio settings?
I see megasquirt users like the mapdaddy 4bar map sensor is this the one to go for?
Any recomendations for what type of map sensor to go for would be appreciated!
superboost
Re: How do i upgrade my map sensor?
Postby superboost » Wed May 03, 2017 10:31 am
Come on guys! So many pros and not one of you can answear my question?
superboost
Postby racingmini_mtl » Wed May 03, 2017 11:56 am
Any question on custom hardware should be directed at the hardware manufacturer because most people here have no idea what it is. So you should ask mslabs.
racingmini_mtl
Postby superboost » Mon May 08, 2017 6:02 pm
racingmini_mtl wrote:Any question on custom hardware should be directed at the hardware manufacturer because most people here have no idea what it is. So you should ask mslabs.
Thanks for taking the time to help me out.
superboost
Postby benckj » Mon May 08, 2017 9:06 pm
From what I understand it would be as easy as you indicated. The MAP sensor is an add onto the board so simply sway out with larger range. Best to inquire through the site and read docs.
https://www.diyautotune.com/product/map ... orrection/
jim
MSPNP v2 with 3.57 firmware
Toyota MR2 98 3sgte
TD05sl2-18g (billet wheel & high flow turbine)
A2W IC
WI with 50/50 meth/water
benckj
Return to How Do I...
