I am about to update my MS1 2.2 board to drive my LS truck coils number 12558948
I can not find the VB921 at RS or farnell as advised to use in the MS1 spark document
Ive searched the forums for what others have used
2 parts come up BIP 373 which I also can not find and TC4427CPA which I can get at RS.
What is being used in the UK surely am not the only person who cant find these?
Cheers Justin
LS coils wasted driver replacement for VB921?
Re: LS coils wasted driver replacement for VB921?
VB921 has been obsolete for a number of years. You don't need VB921 or BIP373 to drive LS coils. You only need a small signal transistor with a pullup e.g. 2N3094, 2N2222.
Thanks For reply
Am Just getting back into all this after leaving it alone for about 4 years so am a little rusty. lots of reading modding and testing with stim to do.
Sorry if questions may be a bit daft.
Cheers Justin
Cheers Justin
Or you can use the TC4427, 1 for every 2 coils.jsmcortina wrote:VB921 has been obsolete for a number of years. You don't need VB921 or BIP373 to drive LS coils. You only need a small signal transistor with a pullup e.g. 2N3094, 2N2222.
Support the developers!
what might be the reason for this. I put a timing light and ensure that the ignition is correct.
Get Braindumps demos for Test-king.com - cisco certification Our high quality itil prepares you well before appearing in the final Test-king.com cissp certification and http:hsbc.edu exams dean.edu
