I want to run wasted spark on a six cylinder (currently single coil and distributor). I need a coil pack, compatible spark plug wires, and some way to attach wiring to it. Coil packs are everywhere but I haven't seen any with screws/studs, instead it's some plastic doodad and the connector that mates to it is not included. For instance, what type of connector plugs into an EDIS6 coil pack? Junkyard hunting is not an option right now. Alternatively, what spark plug wires fit an IGN-6?
Running six of the old Bosch canister coils would be pretty funny but the extra weight would be substantial ;)
source for coil pack WITH connections?
Re: source for coil pack WITH connections?
DIYAutotune has a pack that is reasonably priced and uses 4 pin weather pack connector on primary side.
Works well.
Works well.
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
The DIY IGN-6 Uses GM HEI style plug wires
Support the developers!
