2nd trigger and Shift-lightoutput is the same?
youask
Post by youask »
If i read correct if you want to use the 2nd trigger input for ignition you have to wire it up to U11/PTC4 . But also if you want a seq-light shiftlight you use the U11/PTC4 as an output?
Is it possible to use it with both if you use a 1k ohm resistor from U11/PTC4
No.
Use one or the other, not both.
It is impossible for the pin to be an input and an output with a different function at the same time.
youask
Post by youask »
ok, then i won't :) thx
Fii
Post by Fii »
Is there a possiblity to use both of these features at the same time?
Maybe one of them could be mapped to a different pin? I could not find an appropriate setting in MT, though.
