If i read correct if you want to use the 2nd trigger input for ignition you have to wire it up to U11/PTC4 . But also if you want a seq-light shiftlight you use the U11/PTC4 as an output?
Is it possible to use it with both if you use a 1k ohm resistor from U11/PTC4
2nd trigger and Shift-lightoutput is the same?
