Horst,
Normally if the module does not support Multispark it will just not give you any commanded advance, it's possible the non-multispark module interperets the Command as advance, but I know you won't get any commanded advance if your module doesn't support Multispark.
Dual EDIS 6 wiring
Hello Scott,
double mystery, recorded rpm was ~700...800 < 1100 --> my map says fire at 10°BTDC.
Will try to enable Multispark and rev to rpm > 1100 to 'feel' advance. Maybe I should scope EDIS without SAW signal in 'limb home' mode to go sure that wheel is set at 10°BTDC exactly.
»Horst
»Horst
MS1 V2.2 MSnSExtra 025x1 'EDIS' MT2.25b627, flat twin, MPI, dual ego feedback
_________________
DIY CDI project http://www.molla.org/DIY-CDI
_________________
