MegaSquirt 'n Spark-E ignition options - I'm so confused.
Hi!
I'm using mine MS without any problems - runing EDIS4 - it's simple and instruction are so clear to follow. A friend of mine is very interested in MS and want to use it on his Opel engine, but here is the problem - we can't understand/choose ignition options.
What we have:
Opel engine have 60-2 crankwheel;
An sensor on that 60-2 wheel but we don't know is that a Hall or VR - 3 wire sensor;
Bosch module
and a single coil.
I think that we can use wheel decoder. But theres no clear instruction how to wire all that stuffs...
If we get that schematic:
Can we use LED17 intead FIDLE, so we can use Ford or Bosch PWM idle valve?
Also - how can tell is that a Hall or VR? And if this is VR is that schematic is needed to use our VR? Is there different types of VR's?
Please help us.
Thanks.
What we have:
Bosch module
and a single coil.
Please help us.
Thanks.
Re: MegaSquirt 'n Spark-E ignition options - I'm so confused
This is true and I want to draw some up.disc wrote: I think that we can use wheel decoder. But theres no clear instruction how to wire all that stuffs...
To find out what your sensor is, get a voltmeter and check what is on the wires. If you are able to back-probe the connector it will help a lot.
If you find one wire is +5v or +12v then you have almost certainly got a hall sensor. Now if you turn the engine by hand one of the other wires should go from 0v to +5v(or +12v) and back as it passes each tooth.
Or... if you have a VR sensor, the AC voltage across two of the wires will increase as the engine revs increase.
If you have a VR sensor then the V3 board will make life a lot simpler as it has the necessary circuit built in. For V2.2 you have to build the LM1815 circuit.
On the coil side, you can either keep you module or use the VB921 ignition driver that comes on the V3 board.
Ok...
Here is my schematic:
1. Can we use LED17 as spark output and it's the correct way?
2. Do we need Tach signal from coil to MS?
3. If that we have is VR how to connect it?
4. "LM1815 based VR sensor conditioner for V2.2 or v1.01 - optional is a 390R resistor across the VR input. " - where to put that 390R resistor?
Sorry for my silly questions, but more instructions needed.
Pretty close, but delete the red wire from the coil back to the Megasquirt.
The LM1815 circuit provides the tach signal from the 60-2 wheel.
A tach signal is ONLY taken from the coil is fuel-only installs.
My brain was faster than my fingers in my previous post, and I have now edited it to correct a typing error.
Basically, yes, like you've drawn, but no connection from coil negative back to the Megasquirt. The VR sensor and LM1815 provide the tach signal internally.
The +ve wire from the VR sensor goes to the 18k resistor, the other goes to ground - as close to the LM1815 as possible. You may need to fit a 390R resistor across these wires.
Hi again!
The idea with Opel engine was not very clear for the owner of vehicle, so that MS (V2.2) now goes to turbocharged BMW
Here is the same problem... how to co connect everything?
Please someone to complete my drawing for VR sensor. Where to connect that 3 wires? How to find +ve wire from the VR sensor because engine is just rebuild and it's not running . Where goes third wire from VR sensor?
Does VR conditioner needs ground (I see 5V but no ground?) and where is connected to circuit?
Ford Zetec Turbo in progress... MSnS-E, EDIS4, LC-1 ect. The engine is running @ 12Psi
The bottom line of VR Diagram should be connected to ground.
If your VR sensor has 3 wires that means that one is shield other are Ve+ and Ve- (or it is not VR sensor it can be Hall). So you should connect Ve- and shield to ground on PCB.
How to recodnize which is Ve+? I'm doing this with scope watching a polarity of signal.
One problematic point of your projects can be how ignitor and coil will go together. I mean that if ignitor is a "smart" you not have control on dwell and on current in the coil.
Regards
_________________
MSnS-extra v2.2
Regards
_________________
MSnS-extra v2.2
