te51levin wrote:OK, now I really need some help. I really messed up. I wanted my thermo sensors to be accurate, so I used EasyTherm to set them up (turns out they are apparently the same as Bosch sensors, which makes sense since it's really licensed L-Jetronic anyway). What I failed to notice is that after doing that, EVERYTHING went back to base maps. The car ran horribly, so I started setting it back up the way it was. Unfortunately I didn't remember about the dwell settings, so I roached the igniter. Not cool!
Now, I think I have the board set up to work the coil directly. I have the VR921 installed at Q16 and the whole VR circuit is in place. Jumpers are as follows:
IGN to IGBTOUT; IGN is pin 36 going to coil (-)
TSEL to VROUT
TACHSELECT to VRIN
IGBTIN to 330-ohm resitor to top of R26
I also have the following left over from the VAST setup:
D1 (jumper, not diode) to 1K resistor to D9 (non-banded end)
D2 is still a jumper, not a diode
I have yet to run this. I think it'll run the coil OK, but I want to be able to run the tach as well. What exactly powers the tach? And can someone with experience/wisdom/courage comment on my progress so far so I don't fry something else, like a tach or the MS or...?
Can I mix and match jumpers to get a signal that the tach likes while still using the VR921 and VR circuit to drive the coil?
Should I install a diode on D2?
I too have fried my ignitor after updating my firmware and not checking the dwell settings once (defaulted to 75%=cooked ignitor)... I hit up the guys on MR2OC.com and found another one cheap. You could do the same or....
With the fried ignitor and still using the hall/opto input-- when you turned the engine over were you still getting a TACH signal? If so the ignitor is still doing part of it's job and shaping the VR sensors output into a square wave. You could then leave it in place conditioning the VR sensor signal into a square wave and continue to use the Hall/Opto input-- that's up to you. Or you could probably ditch the ignitor altogether and use the VR input on the MS to condition the signal for you if you wanted to, which looking at the jumpers you've set looks like the path you've chosen, and should work fine.
You VR input jumpers look fine. You don't need to mess with D2 as you're not even using the hall/opto input anymore.
You're output to directly fire the coil looks fine too, assuming the (+) terminal of the coil is getting 12v+ power in the CRANK and RUN positions.
You need to make sure SPARK OUTPUT INVERTED is set to YES. You need to use Dwell Control. This two settings will prevent VB921 and/or coil damage.
As for triggering your tach-- the negative terminal of the coil will usually work though you might trace it back in the factory schematics and see where they triggered it from.
