Making MS1 pcb 3.0 work with 4age stock distributor/ignition
Re: Should VAST be considered MS supported?
i would be glad to make a guide regarding this, as im having a hell of a time trying to start an MS project (but i like it )froej25 wrote:What is the protocol for submitting a new kind of ignition to the supported section? To put it on the list with GM HEI, EDIS, etc.? It seems that VAST is near that point. It could save people the trouble of searching for it on the forums- it was pure luck that I found that the 22R-E and 4A-GE use the same system. There's a pretty good source for Toyota information on this site: http://www.autoshop101.com, under "technical articles"; they're *.pdfs directly from Toyota, I assume used to train their mechanics. Gives a good description of what everything does, as well as changes made over the years. They're not FSMs, but in a way they're better; they're more general, and make comparisons between the systems.
i win the internets
Check out http://www.diyautotune.com/tech_article ... ta_mr2.htm
I think it's covered pretty well there, but let me know if I missed anything or if there is anything I can improve--
Jerry a.k.a. 'FoundSoul'
Founder DIYAutoTune.com / AMPEFI.com
The DIY EFI Tuners Guide – How to Install, Configure, and Tune EFI!
Killer Products We've Brought to Life:
MS3Pro, MSPNP and MS3Pro PNP
More info on MSPNP Models
MicroSquirt AMP'd!
MicroSquirt AMP'd!
