Let me first start out by saying I have very limited experience with the EDIS currently, and Karchs’s wheel is the first “non” Ford 36 tooth wheel we’ve actually captured a trace for, so I don’t really have much to compare to it to.
As for it working or not, Being as we were able to get EDIS-8 to fire up to 5600 RPM while spinning a single 4-1/2” diameter saw blade in-front of the VR, (pictured below), I don’t see any real world issues that would arise from the slight difference in the sine wave of Karchs wheel vs the OE. I’m sure Karchs wheel is WAY cleaner and WAY more consistent than some of the other home made wheels I’ve heard about that are running EDIS-X, (actually read on here somewhere that someone “hand filed” the 36-1 pattern into his Small Block Chevy damper pulley….)
At this stage, my only concern would be the voltage produced from any ole VR running on a larger diameter 36-1 wheel. It seems as though the EDIS engineers matched the OE 36-1 wheels and VR sensors on the various vehicles so that they produce similar voltages at those same RPMs (i.e. Ford Explorer, 4.0 V-6 uses a small diameter wheel and a sensitive VR vs the Escorts larger wheel and less sensitive VR). Also of note is the thicker the wheel, the more influence that has on the voltage produced. Does that have any relevance to EDIS? Good question, we don’t know. We do have a theory that there is probably a point at which the EDIS module will fry from excessive input voltage from the VR, and as such, our current thinking on this is to try and mimic the voltages produced at given RPMs to that of the OE setups. The OE systems work and work fine so I can’t see any reason to test fate.
