audi urquattro
audi urquattro
Hello Iam installing MS v2.20 with extra code into an Audi Urquattro(2.3L, cylinder, turbo engine, 330ccm injectors) and the car isnt starting(before it was on autronic engine managment system. It starts after I change the number of cylinders to 1 and number of squirts also to 1. After it I can the engine start but it goes very rough.
I ve changed almost every thing i can.
Could U send me some settings of constants for a 5 cylinder engine (or better screenshots of each setting screens - afterstart enrichments, Req fuel tables & so on)
Thx
Thx
You can not use the same data for your car, it must be configured for your injectors flow
If you have done that, check your fuel pressure.
Start tuning!
http://www.megasquirt.info/v22manual/mtune.htm
Start tuning!
69 - VW 1600 TL - 1915cc, MSnS
86 - Passat 32b GT - Audi WJ (10V turbo I5), MSnS Extra
85 - Passat 32b Syncro - Audi 3b (20V turbo I5) MSnS Extra, 60-2 wheel on crank, 1window distributor as cam sync
You need MSnS Extra http://megasquirt.sourceforge.net/extra/
Start with a lot of
Then....
Download the code http://megasquirt.sourceforge.net/extra/files/
Ignition Information: http://megasquirt.sourceforge.net/extra/setup-msns.html
Original and modified Audi MC ignition maps can be downloaded from the download section of http://32bsyncro.com
Start with a lot of
Then....
Sorry, I do not understand all your questions...kefirsky wrote:Thanks for answer. Can you give me a few advice? I want in order to computer regulated ignition from weight of engine according. Will be a problem with this i MS v 2.2? Which ignition distributor do you have? What do you have components?
I'm using a modified distributor from a HY (2.2 136HP engine). All mechanic and vacuum advance removed, and the distributor is locked by setting the top of the distributor axle in 2 new holes in the lover axle.
The two plates earlier adjusted by vacuum advance is now adjusted to preferred angle and locked with a pop nit
For the cheapest solution you need MS 1 ver 2.2 hardware, and the MSnS Extra software
Hi.
I just megasquirted my 100Q fuel only. Works great.
If you have questions go ahead.
I can send you my setup in My V3 board.
I should do a 200tq with a 2.2T 5cyl soon.
I m using 029f1 firmware.
http://www.efi4tuning.com/files/Msns-extra/
I did not tried the spark yet but i m pretty sure that ll works with a 5windows distr. MS will fire at each event of window and the distr will dispatch the sparks at the right cyl .
The V3 is the way to go. The price differency is not big deal since you can get a V3 partially assembled like the V2.2 . Its around 20$ more than the V2.2 but with more features...
Another thread talk about a 60-2 wheel on the crank...
