Help for AE Tuning
Postby KaPower » Fri Jan 26, 2007 10:57 am
I improved my throttle response greatly by switching from 2 squirts alternating to 4 squirts alternating. 2 squirts simultaneous would do the same thing. (2.4 liter 4cyl engine)
Appearently doubling the squirts per engine cycle enables the MS ECU to respond quicker to changes in operating conditions. The downside of better throttle response is with my 740cc injectors, I now have a required fuel of 2.7, and thats with an inj opening time of .67ms. My AFR's are not as stable as before. So becarefull not to get your req_ fuel number to low. I suppose one could even run 4 squirts simultaneous if there Req_ fuel was high enough...
Does the AE injector opening time have to be changed manually in the ini file, or does it use the inj opening time in the constants page in MT?
KaPower
Postby diegom6 » Fri May 04, 2007 12:31 pm
This is like trying to win the loto/bingo. There so much factors that you have to guess wich it's best for your engine/response. Tune the AE it's going to be a nightmare for me I guess. Oh well...this post helps a lot though.
-Diego
BMW 325is Turbo E30 (m20b30) MS II Extra code X.X (13 or 14) Beta 3.0v board - 2.25MT
diegom6
Postby Peter Florance » Mon Jun 04, 2007 4:26 am
My car is running pretty well now - thanks Andy
At the March meeting I believe you were trying to get my Megatune installation to datalog AE Driven Fuel Percent.
Can you or someone explain how to do that?
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
Peter Florance
Postby whittlebeast » Mon Jun 04, 2007 5:11 am
In old 028h8 just add the line
entry = accDecEnrich, "AccelPCT", float, "%.2f"
to your INI It should work in late 029 also
AW
whittlebeast
Postby Peter Florance » Mon Jun 04, 2007 5:37 am
whittlebeast wrote:In old 028h8 just add the line
AW
Thanks Andy
I aleady have a line in my ini that says:
entry = accDecEnrich, "TPSacc", int, "%d"
Will that cause a problem?
Peter Florance
PF Tuning
Peter Florance
Postby whittlebeast » Mon Jun 04, 2007 6:13 am
Have you tried plotting TPSacc in the graphing program? That should be what you are looking for.
AW
whittlebeast
Postby Peter Florance » Mon Jun 04, 2007 6:37 am
whittlebeast wrote:Have you tried plotting TPSacc in the graphing program? That should be what you are looking for.
AW
Yes, that is what I want. :)
Should I throw out the first TPSacc value as we talked about in March?
Thanks Andy!
Peter
Peter Florance
PF Tuning
Peter Florance
Postby whittlebeast » Mon Jun 04, 2007 6:43 am
I never checked that on the logs Just play it by ear. Its just a pattern thing anyway. What does this motor want and do the numbers look correct. 500% for 2 sec or .2% for .2 sec
AW
whittlebeast
Postby Peter Florance » Mon Jun 04, 2007 6:46 am
whittlebeast wrote:I never checked that on the logs Just play it by ear. Its just a pattern thing anyway. What does this motor want and do the numbers look correct. 500% for 2 sec or .2% for .2 sec
AW
Looking at my logs it appears that the first logged value is the same as the first gauge value.
I'm tuning BMW race car with 3 lb flywheel, so I'm guessing the accel time can be shorter?
Peter Florance
PF Tuning
Peter Florance
Previous
Return to MS1/Extra support
Users browsing this forum: Yahoo [Bot] and 2 guests
