CA18DET Tach noise & Reset Help?
Sounds just like the SR20DET ECU i've got on the bench for mods.
I'll post up some info shortly.
Make sure you run the ground for at least the 3extra VB921's seperately from the main MS ground, I found that helped with spikes.
THe SR20DET had the exact same issues until i made the right board mods.
Try putting your finger on the top of the board on the input to the CPU IRQ pin, if the tach spikes dissapear I may have some circuit changes for you.
Dave
Dave
Are your coils grounded to the valve cover or the block? and is your valve cover grounded.. I ran into that issue on the SR20DET, the coils should ground to the valve cover stud that goes into the head, the valve cover when sitting on its nice rubber gasket was insulated and causing ground noise to feed back and cause resets
Certainly worth a try - someone else on this forum reported a massive improvement when switching.Phoenix3D wrote:The plugs I am currently using are Non resistor type... should I possibly try the Resistor type?
yea its amazing how our big problems are caused by such small retarded things.
150kw to the wheels so thats about 201 wheel horse power.
Are you running stock setup like stock T25 turbo, upgraded SR T25 Turbo?
if your using the stock T25 thats very impressive numbers.
Definatly would like to see some pictures
