Crank trigger question
koden
Post by koden »
Will the EDIS pickup work with a Stainless crank trigger or does the trigger have to be made out of a ferrous metal?
Jim
Post by Jim »
Nope , Gotta be magnetic/ferrous metal , SS is non-magnetic .
It's hard to machine too .
'95 GM 4.3 Vortec V-6
Single Plane Intake w/ported GM Throttle Body
Ported Heads , stock roller cam retarded 8 degrees
MS-II 2.6 , V-3 board , MT 3.0
EDIS ignition , Innovate WB 02
250hp , 28mpg @60mph in a 2 ton wagon
torn81
Post by torn81 »
Could it be painted or zinc plated though ?
PSIG
Re: Crank trigger question
Post by PSIG »
koden wrote:Will the EDIS pickup work with a Stainless crank trigger or does the trigger have to be made out of a ferrous metal?
There are many grades of stainless steel. Some (generally the softer ones) are non-magnetic but many are - depending on the alloy. Check the stock you want to use with a magnet. The better it sticks, the better it will work, however the distance the sensor is set to may be reduced and the resulting VR impulse may be less. Triggered Hall sensors should work as well and maybe better than VR types.
The non-magnetic types tend to have better corrosion resistance. Remember, stainless means it stains LESS, not that it is rust proof in all it's variations. An alternative would be to use iron or steel and plate it after machining. I don't personally know of anyone using stainless in a trigger wheel for reference. :?
HTH,
David
