New official code 029q released
I know that one ,i´ve had that happening every now and then to since i switched to 029q (not running q2). that the ego correction timer switches from counts to ms. and at the same time my switchpoint gets set to ZERO.Rollagti16 wrote:hello, my 029q2 is also changing the ego correction step timer from ign counts to milisec every time i connect my laptop. My we table are also very odd at idle.. How could that be
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
Some more problems I noted with 29q2 code..
Tuning the priming table does not make any difference on prime pulse widths..it´s always 5ms no matter what I do.
Then there is strange reset/halt thing sometimes after start and sometimes when the unit stays on for a while at steady rpm. What I see is injectors not firing at all and engine dies + box goes into non communication state.
This happens sometimes after a while when engine is stopped and can´t communicate with the box until power has been switched of and on again.
There is no logic what so ever in this and it happens randomly..
I´m using EDIS 6 on BMW m20b25 supercharged engine with normal map sensor etc.
Would there be more stable code? I have IAC valve from bosch motronic 3 pin. so the code should be able to control that too.
So not quite steady code yet what I reckon..
Cheers, Sami
It has been always like that.slappala wrote:Some more problems I noted with 29q2 code..
If u choose Power up and priming table it´s allways 5ms: you can choose standard prime then it uses value what you choose.
After 2 sec works like it should be.
Twise: first pulse is 5ms and second is from pw table.
What do I need to do to replicate this issue?snillet wrote: I know that one 8) ,i´ve had that happening every now and then to since i switched to 029q (not running q2). that the ego correction timer switches from counts to ms. and at the same time my switchpoint gets set to ZERO.
For me it has happened MOSTLY (not always) when i´m driving around and start to fiddle with the VE bins in the fuel VE table and hit "burn" while engine is running (on idle those times though).jsmcortina wrote:What do I need to do to replicate this issue?snillet wrote: I know that one ,i´ve had that happening every now and then to since i switched to 029q (not running q2). that the ego correction timer switches from counts to ms. and at the same time my switchpoint gets set to ZERO.
Could be a communication bug between laptop(MT) and MSmaybe ?
Have an old Toshiba portege 610CT (90Mhz pentium) with REAL com port. MT2.25 non beta.
jsut guna throw this in, when im messign with the closed loop idle settings, every now and again (its pretty random) as i change a variable (and not necesarily burn) the megasquirt "crashes" the engie stopps, obviously, and the fuel pump and middle LED stay on constantly.
im fairly sure i can repeat this and capture any info needed. what should i be logging/saving.?
edit also, some of the closed loop settings require a reset to be recognised properly. but im sure they never used too in erlier 29 codes.
220ft/lb@7900rpm@20psi ..13.3@114 .. 1.4 16v rover k-series engined rusty mini.
The same thing happens to me all the time. Also, if you click on required fuel all the settings are back to default. And the last one, If you change any of the constants like injector opening time the car will immediately die and the fuel pump will stay running. Hope this helps.snillet wrote:I know that one ,i´ve had that happening every now and then to since i switched to 029q (not running q2). that the ego correction timer switches from counts to ms. and at the same time my switchpoint gets set to ZERO.Rollagti16 wrote:hello, my 029q2 is also changing the ego correction step timer from ign counts to milisec every time i connect my laptop. My we table are also very odd at idle.. How could that be
-Chris
and I had been thinking it was not apparent here, but it just happened while I was driving. this is with Shawn's hires version, but it did just that, ego switch at 0 and ms from cycles.
KeithG
Posted by email.
KeithG
Posted by email.
Yes, the gauge and MAP-sensor take vacuum from the same point. I have a T-connector on the hose to split it to both the gauge and MS.Karl_Skewes wrote:Anders: Are you gauge and MS taken from the same point on the manifold?
Maybe you have a leak on the MS feed?
I have not changed any hardware outside the MS since i changed to 029q2 code. With the old 021u3 code the gauge and MS read the same MAP-values.
All the other gauges seem to match, CLT, IAT, RPM.
Anders Karlsson
Opel Commodore -77
3,0 24V N/A straight six
MS2-extra V3 mainboard
Opel Commodore -77
Anders,
With the new version of MT (2.25), it requires a different custom.ini and settings.ini. If I were you, I would move all the stuff in the car1 directory to a different place and make sure that the most current verison of these files are in the car1/mtcfg directory as are the inc files for your installation.
Make sure that you go through and edit the settings.ini file to match your setup. Make sure that teh MSQ was not corrupted somehow or a value otherwise overwritten. The 029 code moved a lot of variables around, so there may be a messed up variable for the map sensor on the engine constants page. I noted that the MT fires up with a 115kpa sensor here in this bin. You probably have a 250 kpa sensor and this could be why your readings are ~2x.
KeithG
KeithG
I had my engine running again this friday, and now the MAP-gauges where the same. I took a look at all my settings, made a new req-fuel setting and then it worked. I probably had something set up wrong before.
In req-fuel i had 250 kpa map-sensor by default, so nothing wrong there.
I need to tune the coldstart and cranking settings a little bit, because it was a bit difficult to get started at first. Air-temp in the garage was 16 C.
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
So is this code rock solid yet? I'm not really feeling the Cycle count changes.. but i'd like to be on the general release. I'm also dreading having to change my fuel table..
V3 - MS1 mainboard.
MSNS-E 029v 60-2 wheeldecoder.
024s7 Decoder module.
Full Spark and Fuel control; single coil -distributer.
Somewhere between 029i and 029q it looks like constant baro correction in alpha-n mode got broken. I can't download any in-between codes to find out where it happened but I see in the asm that some tweaks on baro corr were done in 029n.
Ian.
Edit: Found 029m and 029o in my computer of all places. Baro corr (for alpha-n) works in the m version but not in the o version.
Ian.
There was a comment that const baro responded to increases in altitude, but not decreases (IIRC). James made a tweak that supposedly fixed that. I am running constant baro as well and am curious. What is the problem and how did you find it?
KeithG
Posted by email.
KeithG
Posted by email.
I tested realtime baro, but I did not test in alpha-N mode where the standard internal map sensor is used for realtime. My baro changes may have broken that in error.
I have had a look at the code and it certainly appears try to make a correct when alpha-N is selected using the internal baro sensor (which must be left open)
To test this, run the motor and hook a hose and syringe up to the internal sensor and simulate high altitude and see how the PW changes.
I was testing on the stim with a syringe as you say, in 029m the PW would increase slightly and steadily with decreasing MAP, in 029o or 029q there was no change at all. The power needs to be cycled after selecting constant baro in alpha-n. Will double-check the tests again later this morning and report back if I find any more info.
Ian.
Ian.
Ian wrote "Is it not getting switched on? There is simply no response."
Yes, it doesn't get switched on if you don't enable it in the constants page Ian. However 029m didn't require this. It also helps Ian if you don't limit the baro values for processor resets, which were greyed out in 029m, but do affect the range of baro correction in later codes. Have you got it now Ian? Yes thanks Ian, it's all working fine now, sorry about that.
Ian
Ian
