Which versions of megatune and "firmware" can I use for RPM based accel, versions without any bugs, and where can i get those ?
Which versions for RPM based acceleration?
its in the sticky at the top of this forum
http://www.msefi.com/viewtopic.php?t=16087
in a post by whittlebeast, its about the 8th post down tells you where to get the correct firmware/megatune
Use the official code 029q
Clearly the RPM based AE is better for most users i guess.jsmcortina wrote:Use the official code 029q
My installation went faaaar more driveable when i switched to that, mor "SMOOOTH" you could say
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
