fan control ?
elturbonitroso
fan control ?
Post by elturbonitroso »
Hi guys i have a ? im using -led 18 to control my fan .my? is if the led have to turn on when the fan is on or not.
elturbonitroso
nobody
Fastest95PGT
Post by Fastest95PGT »
The LED should only turn on when the fan is activated.
Did you change LED18 to Output 4 in the Code Config screen? Does your fan turn on when it should?
1995 Ford Probe GT ~ Megasquirted & Boosted
275whp/242wtq @ 5.5psi ---- 317whp/287wtq @ 8.5psi
^^^ (thanks to MSnS-E and dyno tuning by me!)
2003 GSX1300R (Hayabusa)
elturbonitroso
yes i change led 18 to output 4 in the code configuration.and no the fan dont turn on. I took the sguirt out of the car and doing a test on my bench with the stim the led is on all the time.but when when the fan suppost to turn on the led turn off any idea of what could cause this.
Last edited by elturbonitroso on Wed Apr 26, 2006 2:07 pm, edited 1 time in total.
mobythevan
Post by mobythevan »
What is the rest of the circuit you are using led18 to drive? Just a relay for the fan?
86 RX7 Turbo 5.3 MS3
elturbonitroso
yes I just did what everybody said to just fit a wire from the - side of the led to lets said i use x13 to output and from x13 to the relay pin 85,86 and 30 to 12v and 87 to the fan.
mobythevan
And the other side of the fan?
elturbonitroso
pin 87 from the relay to the + of the fan and the other wire that i have free from the fan to ground and the 1n4001 from 85 to 86 pins in the relay the banded side is looking to pin 86.
mobythevan
OK, just making sure, sounds like its time to break out the multi meter and check voltage at the relay and fan. Make sure the relay turns on, maybe its bad. Test the fan and test the relay. Sounds like you have it hooked up correctly. I used a relay from a camaro once and the fan fan drew too much current and burned it out after only a couple runs.
elturbonitroso
im thinking that the problem is in the squirt but i will check the relay and the fan.
mobythevan
You added the 1k resistor across the LED right? That is the only other thing I see.
like this:
elturbonitroso
no. but nobody told me that i have to add nothing they just told me to just fit a wire from the -side of the led to 1 of the output x11,12,13 or 14. where i have to put the 1k resistor
mobythevan
I am not sure you have to put it on, you'll have to look on your board a fit it in like the picture shown above, from the - side of the led to the other side of the 330 ohm resistor. Why did we need this again? its been a long day.
elturbonitroso
so i need to add a 1k resistor from - side of the led to R24.
Fastest95PGT
I don't see why you would need that 1k resistor nor have I ever installed one. All of my boards have tested out fine on my car as well.
You do not need the illustrated 1k resistor when using the output as fan control. That is only relevant for an ignition output going to a module.
You must though, install the 1N4001 across the relay contacts to prevent damage to the transistor.
mobythevan
Thanks James, it didn't seem to be needed for fan control.
elturbonitroso
ok i change Q10 looks like thats my problem i will let you guys know.
elturbonitroso
Q10 was the problem i was using a ztx-450 now a 2N2222A everything looks fine in the stim lets see in the car.thanks guys.
