Weird starting issue (Every third attempt)
I have noticed this for a while and have been upgrading the code as it came out but now that the final release is out and the problem is still no solved, I will ask. It seems to start every third attempt. I will crank and it will do nothing, turn the key off, then turn it back on (letting the fuel pump fully prime) crank and no start, but after repeating those same steps, on the third attempt, it will fire. Any ideas? Thanks, Nick
I´ve run into the problem that MS maximum cranking/prime pulsewidth is to small for me on cold starts.
Maybe you have the same problem ?
Peugeot 309GR1990 XU9JAZ(4cyl 1.9litre) 10.8:1 CR with 60-2 VR wheel decoding ,V2.2 card, singel coil and dizzy spark ,360cc 0 280 150 431 injectors. Msns-E hi-res 10d2 and E85(Ethanol) in the gastank.
