Will MS v3 work on a Stock 04 Hyundai Accent Trigger Wheel?
238ur50
Post by 238ur50 »
OK me and my buddy are trying to see if we can make MSnS-E will work with his stock Accent Trigger Wheel here is some pics of the wheel
http://hyundairacer.com/crank
We are trying to use MS on the car with the stock wheel if not we will try Ford EDIS
thanks
richie
rbuecker
Post by rbuecker »
that looks like a 60-2 wheel to me, should be ok
MegaScott
MS/Extra Guru
Post by MegaScott »
Usually the sensor for that type of wheel is a VR sensor, correct? The sensor should have only two terminals. You will configure the VR input of the Megasquirt as per the assembly manual input section. You may have to adjust the pots on the Megasquirt to get a consistant VR signal when cranking. You will have to add at least one more high current Ignition driver as called out on the MSnS-extra web site, if it is truely a 60-2 trigger wheel, You setup the wheel decoder for that type of wheel using wasted spark. You can use four high current drivers to run coil on plug, or 1 coil per plug.
See - http://megasquirt.sourceforge.net/extra ... wheel.html
238ur50
Post by 238ur50 »
its actually a hall sensor
richie
MegaScott
MS/Extra Guru
Post by MegaScott »
238ur50 wrote:its actually a hall sensor
richie
Well, that would be rare, but not heard of. Follow the hall sensor tach input instructions and you should be good. (forget about what I said earlier about VR input.) In some ways the hall sensor input is better, it's easy to interface to the Megasquirt, and you get a consistant level output regardless of RPM. :D
rbuecker
Post by rbuecker »
just call us Miss Information- it is a vr sensor
using MSnS-E, megatune 2.25, v3 main board, code version 029q2
LED17(D14) is set to Spark output A
LED19(D16) is set to Spark output B
when cranking, rpm remains 0 on the display, and neither of these LEDs light up.
pin 7 on the db37 is connected to vr sensor neg
pin 24 is connected to positive on the sensor
we're using pin 29 for cyl 2/3 and 36 for cyl 1/4
i may try moving the crank ground back to the stock harness and remove the ground we wired in the harness, just to remove some of the changes
my question is this: shouldnt the rpm be changing while cranking? all of the other info looks right, afr, tps, etc. the car will not start. with fuel only, it would start and idle fairly well. i'm attaching the new .msq to look at. thanks!
rbuecker
Post by rbuecker »
one more thing, the pots are both fully set at counterclockwise
rbuecker
Post by rbuecker »
.. more to come tomorrow ..
