looks like 60-2 teeth to me. MSnS-E can read that. Count the teeth to make sure. There should be 58 teeth (60-2)
KeithG
Posted by email.
Will MS v3 work on a Stock 04 Hyundai Accent Trigger Wheel?
Re: Will MS v3 work on a Stock 04 Hyundai Accent Trigger Whe
Keith,Keithg wrote:looks like 60-2 teeth to me. MSnS-E can read that. Count the teeth to make sure. There should be 58 teeth (60-2)
KeithG
Posted by email.
Have you played with megasquirting this car?
Me and a buddy have installed a MS with MSnS-E with fuel only, we are trying to get it running good with just fuel only, we are running into some issue.
Like the car stumbles ready bad if you drive it around, but the car idles perfect, any idea?
Also if you need use to test something on the Ignition side
Richie
no clue. I was just commenting that it looks like a 60-2 wheel.
if it runs rough, maske sure your timing is triggering correctly (inverted or no) for accurate timing.
KeithG
Posted by email.
KeithG
Posted by email.
LMAO, i said the samething when my buddy wanted to turbo itcscm094 wrote:I'm sorry but I must ask, why in the world would you want to control the fuel/timing on a hyndai accent?!
its his car
we had an emanage on the car and it just would not let use tune the fuel out
so with the MS will be about to do what we want
btw its a scca car so its kinda a race car
Richie
