i've been struggling using megajolt with MS extra for a while and i didnt realize it only takes one signal wire to run the spark off of the MSnS. do i need to do anything with the PIP pin from the edis module? or is that just an output for something else? i know the megajolt uses it, but does the MSnS need it at all? i see it needs the SAW input, but that's obviously easy to wire up. but really, just one little question out of all of this. do i need to do anything with the PIP wire out of the edis module? thanks!
steve
PIP signal used for MSnS with EDIS?
man! i completely forgot about that! i have to stop posting after long days at work. i think you helped me out before too, thanks again! time to get rid of both boxes under the dash then! thanks roger.renns wrote:Steve,
PIP is wired to your tach input pin on the MS. Without that connection, MS doesn't know the engine is turning.
Roger.
steve
This is shown in the EDIS hardware wiring diagrams.
Start at
http://megasquirt.sourceforge.net/extra
Start at
