Which spark plugs to choose?
Volkkarijermu
Post by Volkkarijermu »
Car is VW golf 1.8 8v gti -88. Normal plugs are NGK BUR6ET or Denso W20EPB for example. Now I'm using direct ignition, wasted spark. What plugs should I choose now? Should I take plugs which are used with OEM wasted spark systems?
Jack
Post by Jack »
Unless you've changed the engine, like increasing the compression ratio, etc., there should not (In my Opinion) be any reason to change plug specifications.
Jack
Good judgment comes from experience.
And where does experience come from?
Experience comes from bad judgment.
. . . . . . . Mark Twain
