Fidle software issue???? Won't reset
Bossman
Post by Bossman »
MS 1, V3, MT 2.25, MSnS-E o24s13
My Fidle works great when you cycle the temps (low to normal), but if the MS is powered with a temperature greater than the shutoff point ( mine is 150* /warmup)
it continues to pulse. I have to turn down the temps, then turn it back up for it to shut off. This is indicated using the stimulator and the fact my vehicle would start mild bucking when I had shut it off and restarted later, but with a warm/hot engine.
Post by jsmcortina »
Are you using PWM FIDLE control?
Could you post your MSQ (File-SaveAs in Megatune)
Bossman
Post by Bossman »
nm
Bossman
Post by Bossman »
any ideas?
Bossman
Post by Bossman »
so nobody has a clue?
rs2000
Post by rs2000 »
yeas it does that, i have noticed it too. It only does it if you turn the temperature pot up on the stim fast. I concluded that this is a situation that would never happen on the car..
So far (about a year) i've been right, it works as expected on the car.
Bossman wrote:so nobody has a clue?
You did not reply to my request for more information.
Bossman
Post by Bossman »
Here it is...
Thanks for looking..
