Strange issue...029o
I've noticed that after a restart(anything other than an overnight cold soak), the engine will missfire slightly at idle..just not real smooth as usual. I found out that if i turn the car off, then restart it right away, it runs super smooth! The SAME thing can be recreated if i hit "burn to ECU" on most of the drop down items, mostly the ignition settings though. Its like the MS needs resetting to get the igniton "synced" or something? I've read/heard talk of interupts and handlers for the code, but i have no clue what they do..The car runs great on this code so far, its never idled/ran better, just this one issue. The missfire is just slight, a few small pops and uneveness of the engine, nothing major. It just runs better if i restart it, or hit the burn button on any ignition setting perameter..wierd! Any thoughts here?
Extra 029o, MS 2.2 Running neon code
-Matt-
1998 Mitsubishi Eclipse RS 420A Turbo- MS2 Extra- 2.1.0 Release
1992 Plymouth Laser RS 4g63 AWD Turbo MS2 Extra- 3.0.3s
That's weird. Can't say I've noticed that.
Yeah, its doing the same with 029q2 as well..i'm baffled.. I notice that when i burn something to the MS while its running, LED 17 & 19 will blink brighter(i run inverted spark out), but the strange thing is, is only one of the LED's will blink brighter at a time, not both. If i hit the burn button again, the opposite LED that didnt blink bright, will now blink, then it runs smooth once again. Its like one channel of the ignition timing gets out of sync from the wheel decoder or something..running 4 cyl wasted spark, neon decoder.gronsaken wrote:I'm experiencing the same problem, I'm running 29q2. I had the same problems with an earlier version too. I will try to get a datalog which shows this...
-Matt-
It's really strange, I've measured the ignition advance when it happens and it's the same. At least for cylinder nr 1, I will try to see if I can measure the other ones too.
I have a 4cyl engine with distributor and hall-sensor in the dizzy, MS V2.2...
Edit: I can't see anything strange in my logs, are there any custom values which it could be useful to log?
I can't get my log from my laptop to my desktop computer at the moment but I will post a small portion of the log where the transition between bad and good idle is shown.
The RPM goes from 800 to about 1200 and the O2 signal becomes more or less stable around 1.0V instead of fluctuating between abit lower, mainly on 0.98V and lower limit at about 0.84V.
I've only got 4 rows of values since I keyed them in manually, let me know if you need any more data to get a better understanding of whats happening.
