Hello everyone,
I'ts been a while. First off I want to applogize to everyone, especially Glen from Glen's Garage. I'd like to clear things up that he is not to blame for the huge delay for the daughter boards. I will be making arrangements with him to compensate, at my expense, those who have paid Glen already and have been waiting. The new boards should be ready in less then 2 weeks. I have updated and included nearly all the circuits from the MSnS_E Project.
1. Dual VR Conditioning Circuit (For those with V3 of the MS board no worries just use one of the two circuits)
2. Sequential Shift Lights
3. 4 Output circuits with 12V contact source
4. Boost Control
5. Nitrous Control
6. High/Low Table Switching (Determined by setting a Jumper)
7. Water Injection Control
8. Launch Control
9. EGT Logging
10. 2nd O2 Sensor Input
11. Narrowband Knock Detection
12. Realtime Barometric Correction
**Tach Output is Simply one of the outputs with a 1k resistor in place of the original diode.
Features:
- All circuitry has been made such that traces are as short and direct as possible.
- Double sided PCB
- Dimentions are now ACTUALLY 4" x 2.75"
- Better Legend and Labeling
- All the pins that need to goto the MS are collected in a tidy Header Pin Connector (20 pin)
- Left hand side of the board has all the inputs (i.e Sensors and Switches)
- Right hand side of the board has all the outputs (i.e Pins for Relays and such)
- Special attention for the EGT circuit so that it is optimal (Thanks Glen)
- The pressure sensor mounts on the bottom (Solder Side of the Board, just like the MS)
- Correct Transistor Layout Markings
I've sent the Gerber Files to the PCB Manufacturer... and will keep you guys posted!!!!
Jacob
*UPDATE*: MSnS_Extra Daugther Board v2.0 - READ
