C20XE DIS Pack
C20XE DIS Pack
Hey all i just ordered my MS kit to use on my Astra GSI, now it has a dis pack on it. im not quite sure how to connect this up to the MS, i was told i have to change everything to the Ford EDIS stuff.......... any help would be appreciated. Im will be Using MSnS E code. i have a nice big turbo to fit once its all running
Why switch to edis?
The Extra has 60-2 decoding, and can drive directly wasted spark...
If the coilpack of the 20xe is the same found on mine (x16xe), you need to drive it with 0/5 volt signal. I've used led 14/17 output transisotrs, for not leave the cpu signals goes to the engine bay... A sort of protection...
