Throwing a code when choosing "AEM Linear" WB in s
i have msns extra and i choose that for the code variant and when i chang the Lambda sensor to AEM LInear i save everything and i try to open up MegaTune and it gives me an error saying there is no 02 configuration selected and ill need to fix it in the settings.ini file,and then it terminated Megatune
I bet the wideband defined in your settings.ini file does not match the file in the 024 ini file. 024 is very old and the definitions have changed. Simply search through the 024 ini file for the aem wideband string then copy that to your settings.ini. Be sure to unset the other wide band settings.
Of course, it would be best to upgrade to 029q2 firmware. This would also solve your problem...
