hey all,
I just did an install on my 1980 Datsun 280ZX. I have a mild cam, jus one step over stock. High compression, stock injectors, nothing too fancy really.
I installed Megasquirt And Spark Extra. I built my own V3.0 board with all the options, and I have it set-up to run off of an optical trigger (1983 280ZX turbo CAS distributor) I am running both fuel and spark on my car, using the VB921 to trigger the coil. I am also running the 029k code. these are all the options I can think of.
anyway, its running rough, like its got low compression on one cylinder or like its missing. All plugs look the same, none are fouled. The poor mans compression test doesnt seem to indicate that its low on one cylinder. It cranks nice and even. Plus, this problem wasnt there with the stock system.
I've made sure the timing is righ on at idle, 10btdc. one weird thing I did notice, was that while Im looking at the tuning window, the pulswidth of the injectors is the same between banks 1 and 2, but the dutycyle on number 1 is about 1.5 times higher than it is on bank 2. at idle its about 2.5% on #2, and about 4% on 1.
any ideas?
Running rough, like its missing on one cylinder....
