Is there a common circuit for fan control for the MS-1, V3 board?
I have found the circuits for V2.2 board, and pictures showing "JS0" and what looks like pin 5 on the DB37 being used for V3, but nothing else.
Do I just build the circuit outlined for the V2.2 board in the proto area and connect it to "JS0" and find which output is connected to pin 5?
Is there a common, accepted way to work this?
Daryl
MS-1, V3 board, Fan Control?
Go to www.diyautotune.com and go to techarticles for the schematic for your setup
500 cubic inches, ms extra, 29v, 2.25,four 52# port injectors in an Auto-Nomics four barrel TB
