Miata Spark - Erratic CAS signal with spark ouputs connected
V3 board MSnSE 029j
I've done the DSM input and output mods, and the car has been running great on fuel only using the CAS for RPM signal. But when I connect spark, the car backfires and barely idles on two cylinders, like the timing is WAY off. I noticed the Tach on megatune jumps around wildly (from 0-8000rpm) when it is "idling" like this. It worked fine when it was on fuel only. I have not changed any MSQ settings. The only thing I have changed is to connect the spark output wires to the ignitor.
Thanks a bunch!
Thanks a bunch!
Yes, i remeber that post where this was discussed. There were one or two people getting some strange behavior using 1k resistors. The 470 ohm resistor was the one used for both of the "pullups", on for the main 12v crank position signal, and the secondary cam 5v signal. You still need the 1k resistor that goes from pin 11 of U1, for input protection in case of incorrect output settings(pin 11 can be both an input and output). Try this out first, it should take care of your issue. As for using the 330 ohm resistors, i'm not too sure on that. I would think it would work, but the 470 ohm have been proven to work 100%..This is all fresh in my head, since i am currently building a MS for a 91 Talon AWD turbo 4g63..
-Matt-
1998 Mitsubishi Eclipse RS 420A Turbo- MS2 Extra- 2.1.0 Release
1992 Plymouth Laser RS 4g63 AWD Turbo MS2 Extra- 3.0.3s
It appears that I fixed the CAS signal by swapping the wires I connected to. Problem is, it runs worse than it did before. It won't even idle now. At least the tach on MT reads the same as the car's tach. 300rpm.
Using a timing light, spark appears to be occuring at about 20 degrees after TDC.
Edit: Aussie, is your pinout on miataturbo.net for a 1.6 ECU? I had the CAS wires connected as you have in your pinout, and I was getting the strange tach behavior.
Upgrade to 029q2. I recall a few bugs in 029j
I got the car to fire and idle by turning spark output inverted off. THis is the opposite of what the other miatas are doing, but the same as the DSMs. The car seemed like it would be idling fine, but the ignitor gets hot quickly, so I haven't let it run long.
Is this spark non-inversion hiding something thats backwards in my car?
How are you firing the coilpack? Are you using VB921's, or an ingitor module from an OEM setup? If you use the 921's, you MUST invert spark output. If you are using an ignitor module, then do NOT invert spark output. If its getting too hot at idle, then reduce the running dwell time. You run dwell control setting, correct? Run dwell control, and try 3.5-3.8ms running dwell, and .5 - .7 ms discharge period.AlHounos wrote:I got the car to fire and idle by turning spark output inverted off. THis is the opposite of what the other miatas are doing, but the same as the DSMs. The car seemed like it would be idling fine, but the ignitor gets hot quickly, so I haven't let it run long.
-Matt-
