I am using MegaSquirt (V2.2 -extra code 024s13 ) on small 4 cyl. engine in fuel only setup with distibutor for the spark.
I would like to finally move to the spark control too, with Bosch ignition module and distributor only for spark to cylinder distribution.
I found this crank pulley and VR sensor from the same type of engine (but Fuel Injection version). This is nice 2-lobe wheel, but the triggering angle is litlle strange, nothing like 60-90 ° BTDC ( the way I see it).
Relocating the VR sensor would be too much hassle, but if it is only option...
Thanks for help,
Regards, Drazen
Crank pulley with two lobes- are these angles usable?
