The LEDs will flash randomly. But when you slow the rpms down to 100 or less, you can see the leds are firing with the spark (led 19, 18, 17, and over again).
This is reguardless of which leds I setup in Megatune. With my 024s9 code it works great.
Also the first 40 - 50 sparks or so when first powered on, act normal and the single LED 17 flashes as it should. Then it will start alternating after 40 - 50 ish sparks.
I have been driving on 029p with my own inc files for a while now and have not noticed this in practice. I am running 4 spark outputs, 36-1 wheel with second trigger.
cscm094 wrote:Also the first 40 - 50 sparks or so when first powered on, act normal and the single LED 17 flashes as it should. Then it will start alternating after 40 - 50 ish sparks.
I had a similar issue that Peter Florance fixed - I had bad solder joints.
I just upgraded to 029q2, and did not notice any thing like this..I'm running LED 17 &19 as spark outputs, for 4 cylinder wasted spark..Runs like a champ so far..
