PWM-Idle question, hardware
MS1 V2.2 MT2.25 release MSnS-E 029q2
I´m going to try using the PWM-Idle function, and i have a question about the hardware mods.
I have a TIP121 transistor (hope it´s ok to use, culdn´t find a TIP122)
and i wonder if i should replace R16 from 1 kohm to 510 ohm?
Anders Karlsson
Opel Commodore -77
3,0 24V N/A straight six
MS2-extra V3 mainboard
Opel Commodore -77
I think 1k is fine.
TIP121 should work as well (80V vs 100V) as long as you include the diode across the valve's coil (banded end, cathode, goes to +12V)
Peter Florance
First Fives.Org - The E12 Registry
1981 Euro BMW 528i w/3.5L & Megasquirt Fuel Injection
1981 US BMW 528i "Repo Car"
http://www.firstfives.org
mailto:peter@firstfives.org (peter@firstfives.org)
ssr# 284
From: Anders Karlsson [mailto:oplenserdu@hotmail.com]
Sent: Tuesday, May 16, 2006 6:35 AM
To: megasquirt-mss@msefi.com
Subject: PWM-Idle question, hardware
Anders Karlsson
Opel Rekord -69
Turbocharged 2,2 litre CIH, MSnS-EDIS
This post is at: http://www.msefi.com/viewtopic.php?p=120224#120224
Posted by email.
Peter Florance
ssr# 284
Anders Karlsson
Opel Rekord -69
Posted by email.
Should the diode be connected between Fidle-out and 12V?
My Bosh valve also has another serialnumber, 0 280 140 502 instead of 505 but i´m guessing the only difference is where the hoseconnections are located. Could this be right?
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
Yes that's where it goes.
I don't know if there is any difference. Pin 1 to pin 3 should be about 2X resistance of 1-2 or 2-3 if it's what I think it is.
BTW sorry for hijack, but is there a valve like this with straight-through hose connections? That might fit hoses for aux air valve?
Peter Florance
ssr# 284
Peter Florance
ssr# 284
Posted by email.-----Original Message-----
Sent: Tuesday, May 16, 2006 9:01 AM
Anders Karlsson
Opel Rekord -69
This post is at: http://www.msefi.com/viewtopic.php?p=120255#120255
I´ll try to make a "text drawing". My valve looks like this:
^ out
in > : <--- this is the connectorpins
There are also valves that look like this:
in>---->out
¨ <--- connectorpins
Lousy "drawings" but i´ll just spend hours not being able to add a Paintdrawing here. Hope you understand anyhow.
^ out
in>---->out
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
Thanks Anders
The second valve sounds like it.
Do you know part # or what cars they came on?
Cheers
Peter Florance
ssr# 284
Cheers
Peter Florance
ssr# 284
Sent: Tuesday, May 16, 2006 9:42 AM
^ out
in>---->out
Anders Karlsson
Opel Rekord -69
This post is at: http://www.msefi.com/viewtopic.php?p=120259#120259
Re: PWM-Idle question, hardware
Do you mean some of the 'T' style ones like on this page? http://www.autopartswarehouse.com/repla ... ement.htmlPeter Florance wrote:... BTW sorry for hijack, but is there a valve like this with straight-through hose connections? That might fit hoses for aux air valve?
It lists a few makes/models. If you need a used one I can keep it on my 'yard list as they are generally under $10 for an item like that. NAPA has the Standard Products AC388 below for only $399.
David
I will fill in with another question, about the resistor on the ground wire of the idle valve. Does it have to be 35-40 ohm? I have four 7 ohm resistors that can be connected in series to 28 ohm, would that be enough?
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
Today i tested my PWM-idle setup. I think it works, but the idle rpm gets very high as the engine warms up.
At cold engine the idle was about 1200-1300 rpm, wich is ok. But as the engine got warm the idle rised up to about 1800-2000 rpm, wich is not ok.
Throttle response was very good though...
I may have connected the inlet hose to the idle-valve wrong. I use a connection on the throttlebody, just before the throttle.
Since it is a turbo install, i thought that as the engine warms up, the exhausts get warmer too, and the turbo starts charging.
The idle got lower when i squeezed the hose between throttlebody and idle valve.
I think i will try connecting it before the turbo, so there will be no pressure into the idle valve.
I tried some different values in the settings page, but nothing made any difference that i noticed.
My setup is Bosch 3 wire valve, TIP121 transistor and 24 ohm resistor pack to ground. I also have a 1N4001 diode between +12V and Fidle-out.
MS1 2.2 029q2 MT2.25 release
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
Sorry I missed your post. Yes that's what I'm looking for!PSIG wrote:Do you mean some of the 'T' style ones like on this page? http://www.autopartswarehouse.com/repla ... ement.htmlPeter Florance wrote:... BTW sorry for hijack, but is there a valve like this with straight-through hose connections? That might fit hoses for aux air valve?
David
Thanks!
Peter Florance
PF Tuning
81 BMW Euro 528i ESP Car
PF Tuning
Ahem...Is that....Three Hundred Ninty Nine......US Dollars? Are they nuts? They want people to buy this stuff?PSIG wrote:...It lists a few makes/models. If you need a used one I can keep it on my 'yard list as they are generally under $10 for an item like that. NAPA has the Standard Products AC388 below for only $399.
David
Anyway.
It should look something like this when your all hooked up. You will still need to upgrade the Fidle transistor to something more robust; I.E. ZTX688, TIP1xx Ect...
Just doublechecking. Pin 1 on idlevalve to FIdle-out, pin 2 to 12V+ and pin 3 to ground via resistor. 1N4001 connected between pin 1 and 2 with banded end to pin 2, 12V.MegaScott wrote: It should look something like this when your all hooked up. You will still need to upgrade the Fidle transistor to something more robust; I.E. ZTX688, TIP1xx Ect...
Right?
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
What would be the settings required so that this thing will work on start up? Know what I mean? How can we make sure that if we try and start the car first time we don't have an IAC closed issue.
If everything is wired up the right way the valve should click open when ignition turns on. Mine did anyway, and i removed one of the hoses to check that is really was open before i started the engine.
Although i must tune my PWM-settings some more, because rpm increased a lot when my engine got warmer.
Any suggestions on wich settings i should look at first?
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
Your understanding of the wiring is correct, The only way to know what the values are for your car is trial and error, pick some values and run it if it doesn't work, adjust to suit.Anders Karlsson wrote:If everything is wired up the right way the valve should click open when ignition turns on. Mine did anyway, and i removed one of the hoses to check that is really was open before i started the engine.
Ok, thanks! I´ll just keep fiddling around with it then.
This is the msq i run for the moment.
Edit: i changed from B&G on/off to PWM in the idle control when i tested it of course. Didn´t change any values very much though.
Tried warm up only and closed loop without any difference.
Anders Karlsson
Opel Commodore -77
Opel Commodore -77
just to add to this, i'm using a 3 wire bosch iac valve, and with the 'old' IRF540 way of controlling the valve it works perfect. however, i am now trying to use this new (and much simpler) way of controlling the valve and i have the same problem as Anders. the idle speed is very high. i can hear that the valve is not fully closed even at 0% DC. i have a 40ohm resistor on the closing wire. i'm afraid to try lower resistance values because as it stands the 40ohm gets very warm. any ideas?
1990 Mazda Miata: GM Gen3 V8 swap, 4.8L, custom cam, 2x GT2860R turbos, MS3 + MS3X.
2003 Kia Rio wagon: Mazda B6T/G25MR swap, Miata CAS, IHI RHF5 @ 2bar, LSx truck coils, P&H board, boost control.
