PWM idle always works
ASTB
Post by ASTB »
Hi.
I use a on my Ford Fiesta Turbo MSnS-E with EDIS, V3 Board, code 029q.
I have got a problem with my idle control (Ford PWM Idle Value).
My idle is set up to 800-900rpm. I think its ok.
But if i open the throttle body and go up to 3000rpm,
the PWM Idle Value still works.
So the AFR jumps up and down.
Can i chance the settings, that the value works only under 1300 rpm.
I now, my english is bad. But i hope you unterstand me.
thanks for our help. :oops:
kind regards
ASTB
Keithg
Post by Keithg »
The most probable reason is that the ADC value for the Throttle Position is not set low enough.
KeithG
Posted by email.
ASTB
Post by ASTB »
with "closed loop", the idle is perfect.
Thanks for your help
regards ASTB
Keithg
Post by Keithg »
Great to hear!
KeithG
