Hi.
I use a on my Ford Fiesta Turbo MSnS-E with EDIS, V3 Board, code 029q.
I have got a problem with my idle control (Ford PWM Idle Value).
My idle is set up to 800-900rpm. I think its ok.
But if i open the throttle body and go up to 3000rpm,
the PWM Idle Value still works.
So the AFR jumps up and down.
Can i chance the settings, that the value works only under 1300 rpm.
I now, my english is bad. But i hope you unterstand me.
thanks for our help.
kind regards
ASTB
PWM idle always works
The most probable reason is that the ADC value for the Throttle Position is not set low enough.
KeithG
Posted by email.
KeithG
Posted by email.
