What you think about rpm:
http://www.saunalahti.fi/markusco/roina/megatune2.avi
Wasted spark with bosch 0 227 100 204, dwell 4.0ms and discharge period 1.0ms. 12-1 wheel, trigger angle 57, no MAP used only rpm ignition advance. No fuel used. Board V2.2 with 029q.
What should I try? Megasquirt resets itself about 5 times when driving one hour.
RPM is rocking like the Lordi!
Last edited by Volkkarijermu on Fri May 19, 2006 11:04 am, edited 1 time in total.
- MS/Extra Guru
Re: RPM is roking like the Lordi!
To me the rpm looks fairly normal. relatively stable, slight hunting, nothing to write home about. I would personally hook up the MAP sensor so you can have a true timing map. Even old style mechanical distributor systems had a vacuum advance can that made the ignition map rather complex.Volkkarijermu wrote:What you think about rpm:
As for resets, that's usually due to inadequate grounding or ground loops or noisy power (failing alternator/regulator)
